How much boost is normal?
Old Apr 10, 2012 | 12:24 PM
tomecsi's Avatar
Default How much boost is normal?
How much boost is "normal" in a 2000 S70 GLT SE? In other words, with all factory equipment, what should the boost gauge read during acceleration?
Old Apr 11, 2012 | 06:18 PM
Well, that car did not come with a boost gauge but if you installed one, I believe the GLT's boost about 6.5 psi. they are low pressure turbo's.
Old Apr 11, 2012 | 06:25 PM
JRL's Avatar
JRL
6-1/2 to 7 or so
Old Apr 11, 2012 | 07:45 PM
tomecsi's Avatar
any idea what max would be?
would a turbo from a T5 simply replace the factory low pressure turbo on GLT?
Old Apr 11, 2012 | 07:54 PM
You can get a preformance chip/ecu from ipd or somewhere if you are looking for more power.
Old Apr 12, 2012 | 05:26 AM
Lifesgoodhere's Avatar
yes...(
the forum says my post if to short so im making it longers....)
Old Apr 12, 2012 | 12:44 PM
ok ....)
Old Apr 12, 2012 | 02:22 PM
tomecsi's Avatar
So, if i found a turbo from a S70 T5 and slapped it into my S70 GLT, is there anything else that would need to be upgraded to make it work properly? Or is it simply just a turbo swap?
Old Apr 12, 2012 | 02:29 PM
You should also get the ECU.
Old Apr 12, 2012 | 10:14 PM
or reflash
Old Apr 13, 2012 | 06:58 AM
tomecsi's Avatar
Thanks guys! I'm on the hunt for a 16T turbo.
Old Apr 23, 2012 | 07:59 AM
tomecsi's Avatar
So whats the better option here for higher performance? A performance chip for my existing stock GLT SE or a turbo and ECM swap from a T5?
azeli73
20
Dec 31, 2019 10:59 AM
boggy
Nov 4, 2011 08:22 PM
boostnm3
Dec 24, 2010 09:33 PM
endneu913
Mar 28, 2010 11:41 PM
aryanvahedi
Nov 18, 2009 08:59 PM
