HPT in an S70 GLT
Old Sep 22, 2009 | 11:21 AM
S70Punker's Avatar
Default HPT in an S70 GLT
I have owned my S70 GLT for about a year, and I know the low pressure turbo is in the GLT and the high pressure turbo is in the T5. Does anyone know if a high pressure turbo in the GLT possible? If so, what else would need to be upgraded/replaced?
Thanks.
Old Sep 22, 2009 | 12:23 PM
gilber33's Avatar
The turbo in the GLT is a 13G and the T5 is a 16T. Any TD04 turbo will work in any Volvo as a drop in plug n play. You can put in a 16T into a GLT if you want. I'm sure a lot of people have done it. I don't know if it would need a new tune or not. And you'll have to make sure the exhaust housings have the same DP flange.
Old Sep 22, 2009 | 03:12 PM
S70driver's Avatar
Many people have done this. An easy swap...
supporting mods would be a upgraded downpipe to a 3" mandrel bent version and a 2.5" to 3" mandrel bent catback system with a free flowing straight through design muffler. Also an ECU isn't needed but it would benefit the upgrade.
Old Sep 26, 2009 | 06:50 PM
BlazeS70's Avatar
If you get the ECU upgrade after dropping in the 16T, you'll probably need to get a couple joints, seals, and etc. upgraded to handle the pressure.
Old Sep 26, 2009 | 07:52 PM
gilber33's Avatar
You sure they use different types of seals on the engines? If I put a 16T on an LPT engine, I wouldn't worry about the seals. The 16T is only a small upgrade from the 15G, so it's not like your going to be boosting a whole lot anyways.
Giorgi.Varamishvili
Jun 24, 2016 11:45 PM
ovlove
Jul 13, 2007 08:22 AM
tupapison
Jun 17, 2006 11:43 PM
c70turbogt
Mar 27, 2006 03:28 PM
c70turbogt
Feb 8, 2006 01:38 AM
