humming from front wheel??
Old May 4, 2015 | 08:40 AM
kennedy759's Avatar
Default humming from front wheel??
2000 s70 glt se, 148k miles, been awhile since I needed to ask a question, but while driving today, I got a humming noise from the left front wheel, hit brakes and it went a way a sec then came back. felt the wheels when I got home and the left front was hot, the rest cool. I have notice a vibration lately like a warped rotor, so is it time for a brake job, new pads and rotors? or do I have a stuck caliper? thanks
Old May 5, 2015 | 10:43 AM
kennedy759's Avatar
took wheel off and brakes look great, I think I have a stuck caliper, going to take it off and check it out
Old May 5, 2015 | 12:02 PM
you should be able to manually press the pad back into the caliper then reapply the brakes to see if it glides or sticks before you disassemble. If NG, get some brake grease, remove the caliper and inspect the pins for corrosion and lube so it can slide more freely. Otherwise you may have corrosion inside the piston and either need to rebuild (hone/new seal) or replace the caliper... I'd try the first two as they are "free". Its quite possible you have warped the rotor so check that out as well.
Old Jun 29, 2015 | 05:17 PM
kennedy759's Avatar
ended up taking the caliper off, greased it, pushed the piston in and out and all is well, its my second daily driver behind my vette and does not get driven enough
cwicker10
Jan 6, 2015 10:25 AM
jeropon
Dec 19, 2013 11:48 PM
s80t6schcik
Mar 22, 2007 03:57 PM
SlavaD
Jul 31, 2006 11:56 PM
Low_Bridge
Aug 8, 2005 01:38 AM
