I replaced the headlight wiring harnesses
Old Nov 23, 2025 | 03:07 PM
admasters's Avatar
Default I replaced the headlight wiring harnesses
Hey there, not much discussion on this but it's worth it. We all know the headlight internal wiring harness disintegrates and FCP has replacement harnesses for about $30. Sure beats buying new or used units.
I resilvered the reflectors with high quality aircraft model paint (real silver) and an airbrush. That's when I noticed the hole below the lowbeam socket. City Lights!
Then I ordered the harness from FCP and 2 W5W bulbs and had the entire setup done in 1 hour. You will have to remove the additional US-spec pigtail, it only has three wires. The stock wiring harness has 4 wires for the additional bulb.
No more shorts, plus City Lights. It's a great look.
city lights on!
city lights on!
Old Dec 29, 2025 | 03:50 AM
dhsyu's Avatar
tie the fishing line to the original indicator spade type connector and pull the line through at the same time as removing the old cable. do this with both indicator wires. Saves you the difficulty of trying to feed the line through by itself.
Tutuapp 9Apps
MLB090
May 20, 2021 12:04 AM
JacquesBlom
2001-2013 model year V70
Mar 18, 2021 09:14 AM
jholtohio
Jan 17, 2014 04:27 PM
TheTrainwreck
Sep 15, 2009 03:08 PM
cbrack
Jul 27, 2008 10:52 AM
