Infant locked car
Old May 26, 2006 | 12:41 AM
sethsigel's Avatar
Default Infant locked car
Help! My driver door was open, and my son accidentally flipped up the llock atch on the inside of the door (the part not visible when the door is closed) and now I can not re-set it. Any advice?
Old May 26, 2006 | 01:00 AM
tupapison's Avatar
Default RE: Infant locked car
I dont quite understand your question
Old May 26, 2006 | 01:43 AM
sethsigel's Avatar
Inside of the door (that is, if the door was open, and you were not looking at the part that's on the inside or the outside, but rather in it) there seems to be a latch that locks the door). If you open the handle, it should release. But in this case, my son has flipped it up into the locked position, and I can not release it...is there a way to re-set it...can I call you?
Seth
Old May 26, 2006 | 01:47 AM
sethsigel's Avatar
I figured it out. You've got to pull on the handle at the same time as you squeeze the latch, and it will release. Whew.
mythirdvolvo
Jul 6, 2009 08:43 AM
mythirdvolvo
Jul 1, 2009 02:01 AM
richcar2k
Nov 11, 2008 08:34 PM
psa
Apr 21, 2008 09:35 AM
MNVS60
Sep 18, 2005 10:23 PM
