Instrument Cluster Failure
Old Jun 10, 2011 | 03:53 PM
gformica's Avatar
Default Instrument Cluster Failure
After changing the battery in my 1998 S70 T5, my odometer (digital) went blank. The RPM and speedometer also stopped working,
I had read that this issue could sometimes be resolved by:
1. Disconnecting the neg terminal of batter
2. Turning the ignition to discharge the electrical system
3. Re-attaching the battery after 30 seconds.
Unfortunately, this did not work.
Any help with this would be greatly appreciated.
Thanks
Old Jun 10, 2011 | 04:31 PM
tony1963's Avatar
You probably have a blown fuse. Check them all.
Old Jun 11, 2011 | 11:39 AM
boostnm3's Avatar
You must have shorted something out. You will have to take the cluster out, take the back off and inside there is a fuse which is most likely burned. Its a special fuse though that you will more than likely have to get from a dealer but maybe you can find one somewhere else. Good luck
Old Apr 26, 2013 | 04:20 PM
Aylanbell's Avatar
I have had these problems too. I took the dashboard instrument cluster apart and did not see any fuse.
volvo5volvo
May 29, 2012 05:46 AM
WezoWP
Feb 19, 2010 08:49 AM
autobeef
Oct 17, 2007 12:00 PM
cool_kyle_3000
Mar 5, 2006 11:29 PM
oalsa
Nov 16, 2005 11:12 PM
