Intermittent Stalling 1998 Volvo S70 GLT
Old Apr 6, 2013 | 10:33 PM
Josh Estepp's Avatar
Default Intermittent Stalling 1998 Volvo S70 GLT
Hello I have been having some random stalling with my oil and battery light coming on, the car has 220,000 miles on her and is driven 75 highway miles daily with the original turbo, and most other components to my knowledge. I am replacing the oil pressure sensor now to see if that helps, i am not able to pull codes at this time due to not having a scanner at the moment. Have had faint smells of gas coming when i fill up usually and sometimes uses the first bit of gas kinda quick. Havent checked fuel filter yet need to know location if anyone could help me there. And have some other simple checks for me to do im pretty knowledgeable on most of the parts under there. Just dont know where to start without a code scanner.
Thanks
Old Apr 7, 2013 | 10:00 AM
So went through everything MAF, Oil pressure sensor, and cleaned out the IAC valve. Still not starting. No fuel pressure at fuel rail relief replacing fuel pump now.
Old Apr 7, 2013 | 06:47 PM
New fuel pump replaced Import direct kit from O'Rielly's which to my suprise came with a Walbro brand pump install was pretty easy. She Runs great. No codes to report.
davey778
Oct 22, 2020 11:17 PM
Giorgi.Varamishvili
Jun 24, 2016 11:45 PM
fantastcandy10
Sep 30, 2013 08:13 PM
AudiDefector
Nov 14, 2009 05:09 PM
