losing power in '98 s70
Old Mar 20, 2006 | 05:41 PM
bjay167's Avatar
Default losing power in '98 s70
Im suddenly losing power in my '98 s70. I start off okay but when I press on the gas pedal nothing happens, the tach needle does'nt even rise up to 2000, not even when the pedal touches the floor, then it goes into kickdown and suddenly lunges foward and its okay for a while, goes thru the gears then it happens again......quite dangerous..What could be causing this?? The codes say some of the cylinders are misfiring and my independent volvo guy says that could be caused by a faulty 02 sensor. What do you think?
Old Mar 20, 2006 | 09:28 PM
Default RE: losing power in '98 s70
It could be many things.
Did he tell you what the codes are?
It could be a mass flow sensor,Throttle position senssor,Dist cap and rotor, Plugs,wires,O2 sensor, ETC
Cris
Mar 15, 2008 09:05 AM
Pb231
Mar 8, 2008 07:22 PM
go2sharks
Feb 25, 2007 12:12 AM
DACouture
Feb 19, 2007 10:57 PM
mozhan
Dec 1, 2004 06:38 PM
