Lost power after timing belt replacement
Old Jan 29, 2011 | 02:32 PM
wweeksvolvo's Avatar
Default Lost power after timing belt replacement
Replaced timing belt on 98 s70 with mechanical tensioner, cam marks are at 3 and 9 at top dead, cant locate mark on crank, looking for any help on lost power. there was a diagram of what marks should be, unable to locate it again
Old Jan 29, 2011 | 05:14 PM
Did you take the outer serp. pulley off doing the job?
Old Jan 29, 2011 | 08:55 PM
NoLifeTilBoost's Avatar
The mark can be REAL hard to see especially if you dont pull the serpentine pulley. If you remove the starter motor there is a plug behind it in the block. Pull the plug, insert a 6" long 3/8" ratchet extension into the hole, then turn the motor gently counter clockwise until it hits the stop. That's your mark.
Old Jan 30, 2011 | 08:02 AM
I did remove the serp pulley, I even redid the entire procedure yesterday to ensure car is in time. After 720 degrees of rotation the marks still line up perfectly. engine code of p0116 for faulty coolant temp reading was pulled yesterday as well. dont know if that could add to problem. Car is really sluggish with hard shifts...
Old Jan 30, 2011 | 08:53 AM
The ECT code can be making it run crappy.
Old Jan 30, 2011 | 11:32 PM
gdog's Avatar
Did you ever locate the TDC mark on the crank? It is hard to see but it helps if you know where to look for it; it's a notch on the back of Tbelt crank pulley; see attached diagram.
Attached Thumbnails Lost power after timing belt replacement-850_timing_mark.jpg
Old Jan 31, 2011 | 05:04 PM
replaced thermastat and car seems to run a bit better, atleast we have heat again. I have cam pulleys set to center of holes, any benefit of adding or retarding any time through this adjustment. have read different opinions on advancing time on exhaust side.
H2OSBLGT
Apr 21, 2013 01:31 PM
koi1
Mar 6, 2011 09:05 AM
turbo940
Mar 31, 2008 04:35 PM
philly215
Jun 27, 2006 12:39 AM
