MAF: OE vs aftermarket
Old Oct 13, 2010 | 10:04 AM
col323's Avatar
Default MAF: OE vs aftermarket
The mass air flow sensor (air mass meter) failed on my daughter's 1998 S70 GLT turbo. The failure meant a flat bed trip home.
I replaced the failed unit with a rebuilt unit from Napa. It worked for a few weeks, then failed. Napa happily honored their warranty and replaced it with another rebuilt unit. It failed after 2 days. It seemed unlikely that two units were bad so I replaced the connector with a new Volvo part. No luck.
A bit of research on the web and this forum showed some folks thinking that one should only use new Bosch unit. I purchased a new one from IPD and compared the two units. There is a visible difference in sensor components, the aftermarket unit looking very cheap.
The new unit has been installed for a few days and is working fine. Too soon to definitely state the new OE part is superior, but I wouldn't mess around with a rebuilt aftermarket piece again.
Joe
1998 S70 GLT turbo, 180,000 miles
Old Oct 14, 2010 | 11:41 PM
spaded09's Avatar
I got one off ebay couple years ago and it was aftermarket so it made cel to come on, then i put oem one and cel went away so you decide.
Old Oct 15, 2010 | 09:31 PM
Carrots's Avatar
A lot of reman sensors are bad news, I've found. It seems like many rebuilders just clean the sensor and do a quick check, then box it up and ship. There's probably decent reman sensors out there, but I have no names, and I usually just use Bosch or other quality new sensors, though I'll use an OEM used sensor when dealing with a customer who can't afford a new one.
Old Mar 7, 2011 | 12:46 AM
rjdesi's Avatar
I have a used replacement that I installed and then the car would not start. Are there adjustment that I have to make after installing a replacement? A used BOSCH replacement (exact part number)???
Thank You
Old Mar 13, 2011 | 12:28 PM
col323's Avatar
There is nothing to adjust. Either it will work or won't. Make sure your connections are solid and the contacts are clean. My advice: go buy a new Bosch unit.
driftin V
May 23, 2006 01:38 AM
WagHag
Apr 18, 2006 02:14 AM
ccsct203
Jan 14, 2006 11:58 PM
azeli73
Sep 13, 2005 09:36 PM
Mr Zed
Aug 12, 2005 01:18 AM
