Major Oil Leak
Old Apr 24, 2013 | 11:55 AM
cbstv's Avatar
Default Major Oil Leak
My 2000 s70 glt-se with 165k has all of a sudden began to spew out oil from behind the timing belt cover. It basically empties most of the oil out in a couple of days....not even on the dipstick. there's oil all over the timing belt as well. any ideas?
Old Apr 24, 2013 | 12:55 PM
miealder's Avatar
Probably the crankshaft seal that has blown, what state id the PCV in on the car if this is blocked it will cause high pressure within the crankcase which can blow seals. With the engine running pull the dipstick out and does it puff much smoke out of the dipstick tube as this is a good sign of a blocked PCV - Mike
Old Apr 24, 2013 | 01:19 PM
cbstv's Avatar
assuming the pcv valve is blocked, is there a way to decrease the oil flow, or is a blown seal a blown seal? also how much should this repair generally cost?
The Space Monkey
Jul 12, 2017 11:52 PM
tmixdorf
Jan 9, 2011 10:07 AM
angusjustice
Aug 30, 2010 12:03 PM
BriGuy
Sep 7, 2007 11:53 AM
sloburn88
Jun 25, 2007 10:17 AM
