Mass air flow replacement
Old Apr 30, 2010 | 04:33 PM
billybob420's Avatar
Default Mass air flow replacement
Hello,
I was driving my 98 S70 today and upon trying to pass another vehicle, I accelerated and the car struggled to pass. It chugged quite a bit then all of a sudden my check engine light came on. Could this be my mass air flow sensor?? If so is there a sight somewhere that would provide some info on the replacement procedure?
Any help would be greatly appreciated! Thanks
Old May 2, 2010 | 08:49 AM
cn90's Avatar
I got the exact same symptoms and it was a bad MAF.
1. Check the code, probably P0103
2. Use ONLY Bosch MAF, nothing else.
I bought from ebay for $150 (the cheapest price).
Do NOT buy "MPG" brand on ebay, it is a bad copy of the MAF.
3. Replacing MAF is straightforward:
- Locate the Air Filter
- The MAF is just next to it. There is really nothing to it.
- D/C the clamps (screwdriver and Torx keys).
- D/C the connector.
- There is an O-ring on the Air Filter Side(standing facing the engine, the O-ring is on your R hand side), so make sure the O-ring is not lost.
Overall, there is really nothing to this DIY, if you can replace a light bulb, you can do this job, very easy.
For now, you might want to unplug the MAF so the car does not stall (it runs on LIMP HOME mode) until you get the new MAF.
Some people may tell you to clean with MAF with CRC cleaner, it is usually a band-aid fix then the problem will come back. Best is a new BOSCH MAF.
Good Luck.
Old May 2, 2010 | 01:31 PM
Thanks CN90. Your info is greatly appreciated!
jerryman
Oct 28, 2006 07:35 PM
RocknTommy
Jul 20, 2006 09:20 PM
reg
Jan 1, 2006 11:41 PM
rgarrett
Sep 19, 2005 05:02 PM
floryed
Apr 14, 2005 10:51 AM
