master cylinder bad?
Old 02-03-2017 | 10:31 AM
kennedy759's Avatar
Default master cylinder bad?
2000 s70, glt se, when I push down the brake pedal, it goes past the spot it usually applys the brakes and applies them almost at the end of the pedal travel, bad master cylinder? When the pedal passes its usual spot I can feel slight resistance, thens it gone. no codes or warning lights
Old 02-04-2017 | 10:59 AM
Psaboic's Avatar
First check the brake fluid level and see if it is low. I suspect either a leak in the brake system, a bad master cylinder, or possibly a bad power brake booster, but am leaning toward a bad seal in the master cylinder.
greenbluei
08-08-2012 09:32 PM
Dalbery
07-22-2007 11:29 AM
WagHag
01-02-2007 10:09 PM
suter
11-22-2006 10:13 PM
lmyarana
10-01-2006 10:10 PM
