need 98 s70 strut info
Hey guys, I was wondering how to tell what I need to replace...
- How do I tell if I need to replace the spring seat, the strut mount or the strut itself?
What im trying to say is, what do I need to look/listen for to tell when each needs to be replaced.
- I alsodid a little research on this site and found a few threads that Tech wrote in and he said that when you turn the nut under the hood and it turns... it is bad, my drivers side turns although my passenger side is rubbery and wont turn. What exactly is the problem when this happens?
The problem with my car is it makes thunking sounds when I hit a imperfection in the road or when i make turns.
Thanks in advance.
-Shane
Thanks in advance.
-Shane
RE: need 98 s70 strut info
Alright then the spring seat is definitely bad, this would cause the same clunking sound when I am turning as well?
What would I look for in the sway bar to tell if its bad or not?
Sorry im not the most familiar with this kind of stuff, althoughI am learning.
-Shane
-Shane
In what case would I need to replace a strut mount... I know that I need to replace the spring seats and I also know that its best to replace it all at once but money is tight. So im just wondering what to look for when I NEED to replace the mount itself.
-Shane
-Shane
nortons
02-22-2015 11:14 PM
