Need Help with A/C system
Old May 26, 2010 | 10:03 PM
texan_176's Avatar
Default Need Help with A/C system
It's a 99 S70.
I put on a new compressor and accumilator last year. After a deep vacc. was pulled it was charged and worked great.
This is what it is doing now.
Compressor cuts on and off randomly. The low side line gets very cold near the firewall at times but is underhood temps at other times meaning both compressor is not working and there is lack of flow.
It whistles like a steam engine under the hood for about 5-10 seconds after I shut down the A/C.
Reading on the forum I am thinking orfice tube problem.
Where is that located in the low pressure side?
How do I replace it?
I've always worked on systems with expansion valves in the past.
Old May 26, 2010 | 10:18 PM
The orifice tube is located in the high pressure line like under the coolant bottle. The line splits.
But also is the cooling fan working?
robingichuhi
Feb 22, 2017 04:34 PM
LoveMyWagon
Apr 18, 2010 04:07 PM
abc05
Feb 2, 2010 05:10 AM
IdONtKNOw1230
Jun 20, 2009 10:30 AM
