No heat in the morning
Old Jan 19, 2009 | 07:29 AM
jayturk99's Avatar
Default No heat in the morning
Hi to all, I have a 98 S70 that does not heat up in the morning. The temp gauge barely goes above the bottom. I drive 25 miles to work and it increases slightly. When it is time to come home everything seems to work perfectly. Lately we have experienced temperatures in the teens, could that be a factor? Any help is appreciated.
Old Jan 19, 2009 | 08:35 AM
Default RE: No heat in the morning
I would have to say the thermostat is bad.
Old Jan 19, 2009 | 10:44 AM
jayturk99's Avatar
Eventhough it doesn't overheat? I have to change the timing belt, so I might as well take care of the thermostat at that time.
Old Jan 19, 2009 | 02:43 PM
Yes they break and cause problems.
Old Jan 22, 2009 | 03:49 PM
jayturk99's Avatar
Thanks for the heads up, you are indeed the man. I removed the thermostat housing and the thermostat was in pieces. I replaced it and the gasket, 10 minutes and I have heat again. Good looking out.
Old Jan 22, 2009 | 08:19 PM
Glad all is well with it now.
razak-ms
May 18, 2009 10:03 AM
bobkeenan
Jun 7, 2007 09:25 PM
volvolove
May 20, 2007 07:07 PM
veso_ht
Apr 30, 2007 02:42 PM
tomskuce
Nov 27, 2006 08:12 PM
