Noisy Front End
So about 2 months ago, I completely rebuilt the front suspension (struts, mounts, all hardware, tie rod ends, sway bars, control arms, bearings, CV Axles, EVERYTHING) and now i'm getting some noise from the front right side. Kinda like a rattling noise anytime the road is not smooth, almost like the strut went bad again. I know the dash mounting tabs are bad and the noise is not from those being broken, definitely in the suspension.
Any ideas on where to start the search for the rattling over bumps?
All speeds. Problem is I replaced so many parts, I dont know where to start! Also noticed that now there is a grinding noise when i turn wheels either right or left at low speeds, for example maneuvering a parking lot or in and out of driveway, also a "clunk" when car is put into reverse. Starting to sound like a combination of things.... All was fine for the first two months.
Fluid is good, not a whining noise but a grinding like possibly in the ball joints somewhere. Tranny was serviced at same time front end was rebuilt. The clunk when put in reverse could be the new CV's?.?.? I remember the tranny fluid that came out was very bubbly almost like it had water in it.
I guess I have two seperate issues at hand, the rattling in front end over bumps and the grinding noise. Just gotta get under there and check it out....
Sound like a bunch of things. Clunk could be axle. I got that now but cant seem to find a axle in my area. I got one from fcp coming. I'll let ya konw if that fixes it. It could also be the motor mount on top. Check that out.
CV's were replaced along with everything else. Got them from fcp. Top motor mount is new. Havent had time to jack it up and check it all out. Next weekend I hope to get to it. All work was done by me and a buddy. It's the grinding noise when i turn wheels that bothers me most. Funny thing is that none of this started until i took car in for alignment.
did you replace the spring seats that the main common issue with noise or the right side engine mount. as for the clunk when you put in reverse may be the axle outter spline causing the noise a easy fix is put teflon paste,put it on the axle on the hub sides and not the trans side.
tonymite
Feb 4, 2014 11:06 AM
spankey
Jun 25, 2009 06:53 PM
