...and now the window fell off
Old 09-21-2008 | 09:56 AM
Thecapeman's Avatar
Default ...and now the window fell off
Sounds like my drivers side window fell off its guide - has complete free play within the door. Motor sounds like it still works. I want to get rid off this car now.
Old 09-21-2008 | 10:45 AM
Default RE: ...and now the window fell off
The blocks between the window and regulator might have broke.
Does the window still go up and down?
If so then it might only be the rear window channel.
Old 09-22-2008 | 12:26 PM
Thecapeman's Avatar
Ok, Dad and I removed the door panel and removed the 8 10mm screws holding back the scissor mechanism. Looks like it's a "ball and socket" type situation. (where the "ball" is on the scissor mechanism and the "sockets" are on tracks fastened to the window. One of the green sockets is lightly broken. It is the one on the LONGER track. I'm guessing we will need to replace that part. We also found a cotter-pin looking piece. Where does that go?? Also, how do you get the ball-and-socket situation back together? it seems that you should just have to push them back in, but we we're not able to do this. What should be removed to make this task easier?
[IMG]local://upfiles/13140/CB95CB1E808B4A7E80F104B0BD0DF5F2.jpg[/IMG]
Old 09-23-2008 | 07:29 PM
Yes replace the wheel I would do both since it is already apart.
The cotter pin goes on the wheel.
Yes they pop back together. Sometimes it is a pain. I sometimes use channel locks but you have to be VERY CAREFUL. I have seen people break windows trying to use the channel locks to pop them back in.
_HighVoltage_
05-11-2011 02:26 PM
marsilver
10-07-2010 09:16 PM
jdbs3
06-11-2010 10:12 PM
Simmy65
12-23-2008 04:42 PM
RedTurbo850
03-01-2007 12:02 AM
