ODB-II code?
Old Feb 28, 2009 | 05:12 PM
cm123's Avatar
Default OBD-II code?
i recently just got a check engine light on my 1998 volvo s70 NA..
i went to my friends shop and he plugged in the OBD-II code reader and the codes that came up were;
P0455
P0442
can anyone tell me what they are and if i should get it fixed right away
thanks,
cm123
Old Feb 28, 2009 | 06:17 PM
cm123's Avatar
i meant to say OBD-II code reader
Old Feb 28, 2009 | 07:22 PM
The codes are for an evap system leak. It could be many things.
I got the definitions from this site.
http://www.iequus.com/support/obd2_definitions.php
Old Mar 1, 2009 | 12:35 AM
cm123's Avatar
what do you think i should do?
Old Mar 1, 2009 | 07:13 AM
It could be as simple as the gas cap not on correctly to a bad vacuum line in the system to a bad fuel pump assembly.
I always pressurize the system and check for leaks.
Old Mar 1, 2009 | 09:52 AM
cm123's Avatar
do you think its this http://volvospeed.com/Repair/vacuum_lines.php?
i have also been gettin less than 15 miles per gallon
Old Mar 1, 2009 | 10:01 AM
That is something different.
The evap system is for the fuel tank system.
On the cooling fan on the drivers side is a valve with a hard plastic hose that goes down under the car to the canister under the car. That is the system that is affected.
Old Mar 1, 2009 | 10:15 AM
cm123's Avatar
so i should go to a place that pressurizes and see where the leak is coming from
Old Mar 1, 2009 | 10:16 AM
That would be the best. Some places will smoke test it. That means they will pump smoke in there and watch for it to come out.
busta
May 31, 2008 04:54 AM
JimKW
Oct 5, 2007 12:32 PM
tomservo
Oct 25, 2005 11:58 PM
JimKW
Aug 4, 2005 12:07 AM
nandrolone
Jul 25, 2005 02:21 AM
