oil leak
Old Mar 13, 2013 | 11:58 AM
tigerheart3's Avatar
Default oil leak
Hey guys: I just bought an S70 volvo 1998 from a good friend. I am having two issues. I notice that there is an oil leak I want to say on the rack and pinnion since there is a very slight pull to the right when I brake. Also I noticed that the check engine light is on. I bought it on Monday 3/11/13. The car has been sitting for a bit. A brand new battery was put in. When I got it, I put oil and tranny fluid cause those were down. Last night I noticed the oil leak. Please advise. Also the check engine light?
I am accustomed to working on civics and toyotas. I am new to the Volvo world. Please help
Old Mar 13, 2013 | 03:27 PM
ES6T's Avatar
Really gonna need more info to attempt to guess at an oil leak online. Where do you see the oil?
You'll need to have the codes read for the check engine light.
Old Mar 13, 2013 | 08:13 PM
Hi Tiger, welcome to the forum.
The first thing you need to do is read the NEW 850 OWNER thread. That will guide you through a lot.
Second, what color is the fluid you see leaking? Is it leaking while the car is running?
Third, did you properly check the tranny fluid? There is a big chance that the fluid was correct and you have over filled it. Read the owners manual carefully and properly check the tranny fluid so you don't destroy it.
You should get yourself a code reader or you'll be chasing codes all the time with these cars. The pop CEL's all the time. You can get it checked for free at most auto parts stores. Then report the codes back here.
Old Mar 13, 2013 | 08:14 PM
Oh, the slight pull when braking is likely a bad control arm bushing.
Old Mar 14, 2013 | 07:18 AM
the oil leak is when the car is stopped not running. at least im not aware of it while running but when i park and pull off i see the oil on the ground. it's not alot when i park at the gym for an hr and a half but overnight it looks a bit more
ROBLU540
Feb 20, 2009 07:59 PM
mkelly85
Jan 31, 2008 02:05 AM
pleonard
Jan 7, 2008 06:12 PM
jeannelw
Nov 18, 2005 10:05 PM
witstaffy
Jul 25, 2005 09:31 PM
