Oil leak on the head of the engine
Old Jul 29, 2010 | 01:49 AM
desolator's Avatar
Default Oil leak on the head of the engine
Hi
I purchased my volvo before about two weeks ago and notices oil leak and there was oil on the top of the engine so i figured out maybe the cap.
Anyway i'm not sure where is the leaking from.
I changed the PCV and it was clogged , i opened the read camshaft seal and it was few oil so i changed it, and changed the cap gasket
After doing that i cleaned the top of the engine and start the car, i saw oil leaking from the bolts near the spark plugs, so i checked the torque and noticed that the previous owner tried to do some fixes and he broke some threads on the top of the engine about 3 bolts was have broken threads.
so my question now is if i wanna fix the thread using the heli coil should i remove the head of the engine or do it in it's place.
thanks
Old Jul 29, 2010 | 11:57 PM
gdog's Avatar
Depends on what kind of access you have to the stripped out hole and how good you are at installing heli-coils. If you do it with out removing the stripped out part from the engine, make sure you're careful not to get any metal chips in the engine...
Old Jul 30, 2010 | 06:56 PM
desolator's Avatar
so i better do it from the top without moving the head
Quick Dent
Jan 15, 2012 08:50 PM
seanmathes
Apr 19, 2010 07:56 PM
ROBLU540
Feb 20, 2009 07:59 PM
