oil in my coolant
Old 08-08-2009, 02:17 PM
Volvo4Life70's Avatar
Default oil in my coolant
I have a 98 s70 glt. I got oil in my coolant. Are there any other possible causes than the headgasket? any opinions are accepted.
Old 08-08-2009, 02:56 PM
The transmission cooler might have broke in the radiator.
Old 08-08-2009, 03:03 PM
Carrots's Avatar
What Tech said... or the engine oil cooler in the radiator. This happened to mine shortly after I bought it. It's a BITCH to get all the oil out of the cooling system, too... it will take multiple flushes, and because the oil will weaken them, you'll want to change the hoses, as well. And replace the reservoir, because the oil will probably permanently stain it to where you can't see inside.
Old 08-12-2009, 11:01 AM
If your a DIY guy - Get the Haynes manual for abou $20 Rent a vacuum gage and compression gage from your local parts store and follow the instructions in Haynes manual for compression check and vacuum check. Get a friend to help crank the engine while you run a compression check. This should help you determine if you have a blown headgasket.
Old 08-21-2009, 11:50 PM
turns out I'm a DIY guy. I jumped ship to fast and pulled my head off before asking your guys advice. my head gasket was in very good condition, It probably was the oil cooler. what's done is done, so I took the opertunity to do timiming belt , pump,tensioner,machine the head,change valve seels, cleen intake/throtle body, replace pcv system, new radiator, upgrade turbo, full tune up and ofcourse a coolant flush. since I did it myself it only set me back 770 bucks with oem parts. Car runs like a champ!!!! By the way, for the last coment a comression test doesn't tell you if you need a head gasket.
Old 08-22-2009, 09:04 PM
Carrots's Avatar
Oops... well, at least you have a nice happy engine. And actually, a compression test CAN help pinpoint a bad head gasket if the gasket is blown, say, between 2 cylinders or between a cylinder and a coolant passage.
Old 08-23-2009, 08:01 AM
yes that' right, but if it's between the oil &coolant inlets it wont show. and yes the engint is like new. thanks for the advice you gave me ont the radiator oil cooler. needed one anyway, it had a slow leak.
carson850
01-07-2014 02:08 PM
dow1971
01-07-2012 09:59 PM
gr8lady
06-04-2009 01:29 PM
timk
11-16-2007 08:33 PM
Quick Reply: oil in my coolant
