Oil on spark plug in cylinder 4 and 5, 2000 S70
Old 07-02-2008 | 10:11 PM
rordon's Avatar
Default Oil on spark plug in cylinder 4 and 5, 2000 S70
I have a 2000 S70 turbo with 115000 miles. I replaced the spark plugs with new Volvo plugs when i had a problem with Cylinder 3 misfiring. When removing plug 5, i noticed oil on the old plug when i pulled it out. Oil covered the electrode portion of the plug so it seems that oil is leaking into the combustion chamber. I am interested in knowing if anyone has seen this before and what may have caused this issue. Plug 4 was covered in oil as well. Plugs 1-3 were dry as a bone. I haven't noticed any smoke coming out of the exhaust so i am not sure if it is burning a significant amount of oil. If anyone can help with a solution and explanation of my issue it would be most helpful. THanks
Bobby
2000 Volvo S70 115000 miles.
Old 07-02-2008 | 10:27 PM
Default RE: Oil on spark plug in cylinder 4 and 5, 2000 S70
Was there oil on the top?
Is so it might have leaked by the coils into the spark plug well. If it was dry up top then the o-ring that seals the spark plug well between the cam cover and the head might be bad.
Old 07-02-2008 | 10:53 PM
rordon's Avatar
It was dry up top. How difficult is it to replace that o-ring? do you know where i can find a diagram of the replacement process?
Old 07-03-2008 | 06:07 PM
It is a pain and you need special tools.
How much do you really want to get into it?
jchrisf
01-29-2014 11:33 AM
andrewg
11-05-2010 12:45 AM
futbolfan15
04-02-2010 09:56 PM
thejman
10-31-2006 06:32 AM
Quick Reply: Oil on spark plug in cylinder 4 and 5, 2000 S70
