p0108 and 455 help please
Old Jul 6, 2010 | 04:06 PM
t5s70's Avatar
Default p0108 and 455 help please
Hi I just bought my s70 T5 friday for 500 bucks and have started replacing alot of things on the car. Im still getting a p0108 code which i know is my map sensor next to the washer bottle. My questions is someone has cut the 3 wire harness and put another one on that fits that map sensor, but the factory wires and the new harness wires aren't the same color. I need some help or a pic of someone that can help me with wire colors and what order they go in.
I've replace all my plugs, plug wires, and rotor/cap
this made a huge difference since it had a cycle misfire 2 & 5.
I've replaced alot of the vacuum lines coming off the throttle body.
but the car feels like it should still have more power. Is it possible my car is running in "LIMP" mode with the p0108 cel, and would that slow it down a bit? thanks for the help.
p.s. im putting in a new fuel filter today along with a injector treatment through the shradder valve.
Old Jul 7, 2010 | 10:24 AM
t5s70's Avatar
ok so i found a new intercooler, map sensor, and some wiring harness and it FIXED ALL MY CODES, except im getting misfires when i give it half throttle or try to floor it, feels like its grounding out?
Old Aug 18, 2010 | 07:53 PM
2004VolvoS60_Bilal's Avatar
So did you get this problem eventually fixed? Show us some pics of your car !
cjbmustang
Feb 11, 2013 08:11 PM
mrford55
Dec 9, 2012 06:47 PM
lordhowe
Sep 26, 2007 03:34 PM
TBoone
Aug 8, 2006 12:52 AM
hordezla
Apr 27, 2006 09:40 PM
