Please help!! Engine problems?
Old 09-13-2006 | 07:11 PM
tOfubOi's Avatar
Default Please help!! Engine problems?
Hi all,
I'm new to the forums. I joined because I have a couple of questions and greatly require your assistance. We have a 98 volvo s70 non-turbo which had just accumulated 60k miles. We bought the car new in 97 and it has been driving fine until the past winter. Here's the problem:
The car would sometimes have a problem starting. It cranks but doesn't turn over. The battery was replaced a couple months ago. When the car is started, when I gas it, the rev is very rough at low rpms (800-2000). Sometimes, it will eventually die out. The weird thing is that there's no engine light on either. I find this problem occuring more often when the weather outside is precipitated (rain/snow).
Can you guys suggest any solutions to this problem or whether I need to check something. I would bring it to a dealer, but I don't want to spend that kind of money on the car especially since the retail value of the car has been depreciated so much. Thanks in advance!
Old 09-13-2006 | 09:44 PM
Default RE: Please help!! Engine problems?
When was the last tune up including Dist cap,rotor,wires, and plugs?
Does it seem like it is running out of gas?
Old 09-14-2006 | 02:03 AM
tOfubOi's Avatar
Actually, I dont recall the last tune up, mustve been a while ago. Yeah, the car does seem like it might be running out of gas. Also, I believe this occurs more often when im below 6 gallons of gas left. Im going to do a tune up this weekend and hopefully it would help a bit.
Old 09-14-2006 | 09:35 PM
Fuel pump might be going bad as well.
Old 09-15-2006 | 07:03 PM
tOfubOi's Avatar
ok check engine light just popped up..gonna go scan it..hopefully nothing too bad [&o]
MNWILD
09-10-2020 12:29 PM
02VolvoS80
09-23-2012 06:17 PM
xstuartx91
01-04-2011 10:58 PM
nscoville 87' 760
06-10-2010 01:27 AM
dbmiller719
03-30-2006 01:16 AM
