Please Help? OD, Tach and SpeedO drop
Old 02-19-2010 | 01:07 AM
cliffw2000's Avatar
Default Please Help? OD, Tach and SpeedO drop
We recently bought a 99 S70 and it is now doing something weird!
We had the dealer re-program the recalled Throttle Module and was fine for a while. Problem comes and goes. Was just out of time for getting a new one.
Please let me know if you know what this is.
Symptoms:
* Odometer goes to all zeros
* Speedometer drops to zero
* Brake light comes on (not park brake)
* Check engine light also on but always on
* Will hardly accelerate
* Feels like punching it but holding the park brake so barely goes
Thank you very much for any help.
Old 02-19-2010 | 01:25 AM
chachouu's Avatar
Banned
Might be a bad ABS.
Old 02-19-2010 | 03:17 PM
cliffw2000's Avatar
Originally Posted by chachouu
Might be a bad ABS.
Oh yea, ABS light comes on at the same time.
Can I just disable the ABS? How, pull fuse?
If so, will it pass inspection with that out?
Any other fix?
Thank you so much for your help.
Old 02-19-2010 | 10:41 PM
You can get it rebuilt here for pretty cheap.
http://home.earthlink.net/~vicrocha/...vo_V70_ABS.htm
Old 02-20-2010 | 12:56 AM
gdog's Avatar
Symptoms:
Could a bad ABS module cause these symptoms? Seems more like an ETM issue to me???
At least pull the codes and see what that tells you...
Old 02-20-2010 | 06:36 PM
If it was just the ETM the speedo and odometer would not drop off.
Old 04-11-2010 | 12:21 AM
cliffw2000's Avatar
Default Thanks
Thanks for the replys. About to take it to Volvo next week I hope. It is getting worse now. I had Auto Zone pull the codes a little bit back and several were the ETM. I'll look into the cheaper option posted here. Thanks,
Ilikemybike
01-08-2015 02:53 PM
4cfed
04-26-2010 01:14 AM
obaloney
11-15-2008 06:22 PM
van850
06-21-2006 04:24 AM
