Possible to replace Window Motor w/out regulator?
Is it possible to just replace the driver's side window motor or do you have to replace the window motor AND regulator?
The Volvo Specialist I took it to informed me that I would have to purchase the window motor AND regulator to fix the problem.
The motor is bolted to the regulator so they are two parts. Now getting the motor out you will probably have to remove the regulator. It's a very tight fit and the bolts to the motor are on the back side (inside the door) of the regulator. Junk yard part since it only costs about $15. If you can't get one let me know I have good access to S70's and V70's.
gentlejax2
Mar 28, 2012 06:26 AM
