Radio antenna
Old Aug 28, 2011 | 03:01 PM
mowntnbkr's Avatar
Default Radio antenna
My antenna is making the sound like it is going up and down, and sometimes it moves a little, but it isnt working like it should. If I shut off the car, get out, and give the antenna a push, sometimes it will go down. Sometimes it takes more of a push than other times and lately it seems to be getting harder. If I dont push it, it still sounds like its working but it usually wont move. The sound it makes isnt any different when working properly. Time for a new antenna or can this one be cleaned and lubed? Thanks!
Old Aug 28, 2011 | 08:42 PM
gdog's Avatar
Cleaning it may help, but most likely you're due for a new mast. Even then you may need a new gear inside the motor assembly as well.
Old Aug 29, 2011 | 06:01 PM
9 Times out of 10 you can replace the mass and be fine. It cost about $15 on FCP. You may also want to check the antenna switch write-up in the 850 section. You can cut the antenna off so it doesn't go up and down when you don't need it.
Omead
May 3, 2015 07:44 AM
bsobo
Apr 20, 2010 08:18 PM
alecw81
Jan 7, 2009 05:22 PM
cbgav
Sep 10, 2007 05:25 PM
jmc00v70
Jul 10, 2006 06:52 PM
