Radio anti-theft device
Old May 23, 2009 | 07:19 PM
Rick Cooper's Avatar
Default Radio anti-theft device
When I got my Volvo S-70 from a routine service the radio anti-theft device was activated because the mechanic had pulled the battery out. I entered what I thought was the correct code number (from memory) but I entered the wrong one; I tried again -- wrong number again. Then, the radio display read "OFF." I went home and retrieved the correct number. I thought if I disconnected the battery it would re-set the anti-theft and I could start over with the correct code. No such luck. Then I read in the owner's manual that I need to leave the ignition in the I position for 2 hours to re-set the code. I'm sure that would drain the battery, so I was wondering if there is any other way to re-set the code without turning the ignition on for 2 hours?
Old May 24, 2009 | 08:17 AM
S70GLT's Avatar
It wont drain the battery if the radio is the only item that is on, i.e. make sure fans and lights are off, etc.. I've had to do this twice, I believe it is the only way.
Old May 24, 2009 | 08:35 AM
Turn the switch to position 1 Only the radio position for 2 hours and you should be fine.
Old May 25, 2009 | 06:41 PM
Thanks for the information. I also read that you can pull the fuse for the radio to re-set the device. Sounds easier than leaving the key in the ignition for 2 hours. Any info on this ?
Old May 25, 2009 | 06:45 PM
I have never had that work for me.
Revolvoer
Mar 16, 2022 03:19 AM
lsmith49
Sep 10, 2009 10:03 PM
niccimblack
Dec 30, 2007 05:59 PM
mycarl
Feb 16, 2005 05:47 PM
jayb
Aug 27, 2004 09:29 PM
