Rear Passenger Window won't go up
Old Sep 2, 2007 | 12:47 PM
alecw81's Avatar
Default Rear Passenger Window won't go up
Yesterday afternoon, I cracked my rear windows while I was playing rugby to keep the car (98 S70 GLT) from turning into an oven. When I attempted to get the window back up, it wouldn't move at all. First I thought maybe the switch was the culprit, but replacing it with the switch from the rear-driver's side didn't solve the problem. Then I decided maybe it's the motor, so I attempted to swap the motors between the rear passenger and drivers side, but ran into some problems there. Mainly, part of the component broke. So before I go and do anything else, I figured I'd stop in here to see if anyone had a solution. At this point, I'd be happy to just get the damn window up and then remove the leads so I won't be tempted to put it down again.
Old Sep 2, 2007 | 12:55 PM
Default RE: Rear Passenger Window won't go up
Maybe try tapping on the motor with a small hammer while holding the switch in the up position.
Sometimes that will work.
Old Sep 2, 2007 | 01:06 PM
alecw81's Avatar
Is there any manual way of raising the window?
Old Sep 2, 2007 | 05:52 PM
No unless you totally remove the window motor.
Old Sep 2, 2007 | 08:23 PM
alecw81's Avatar
Well I'm more than halfway there (removing the motor) what would I have to do?
Old Sep 2, 2007 | 08:49 PM
Once the motor all the way off you should be able to move the window manually up.
Then you will need to support it up.
Old Sep 3, 2007 | 03:22 PM
alecw81's Avatar
Well this afternoon I was able to push the window up, then stuck the motor back inside the black-plastic piece (crank?) and screwed the metal housing on to lock the window in place. Hopefully that'll hold and since it's disconnected, I won't have to worry about it going back down.
However, now I've got a wonderful new problem. I can't open the rear driver's side door. It won't unlock.
Old Sep 3, 2007 | 03:40 PM
Yes big problem. When that happens you usually have to destroy the door panel to get it off.
Old Sep 3, 2007 | 03:42 PM
alecw81's Avatar
I guess I'll go fishing with a coat-hanger...
Old Sep 3, 2007 | 03:43 PM
Goot luck. Maybe use the other rear door to judge.
Leave the door panel off the other one and see if that helps.
Old Sep 3, 2007 | 04:23 PM
alecw81's Avatar
Wasn't too difficult actually. I just hope nobody in the back ever wants their windows down, because that ain't happening till I can afford to have an actual mechanic replace that junk.
dman777
Oct 30, 2016 09:43 PM
steelheaddan
Sep 3, 2013 03:47 PM
jipsy
Jan 22, 2012 06:00 PM
850GLTWAGON
Nov 21, 2008 04:14 PM
2001V70
Jan 7, 2007 11:27 PM
