Rear speaker replacement
Old Jan 11, 2012 | 11:45 AM
DaVolvoKid's Avatar
Default Rear speaker replacement
I want to put some 8 inch subs in the place of the factory rear speakers to finish my speaker job. I will be running the subs off an amp but I am wondering if the factory mounts will support the weight of the subs. Has anyone done this before and has it worked well or not. Thanks for the help.
Old Jan 11, 2012 | 02:32 PM
tr_car_nut's Avatar
I think the ones in the rear deck are 6 1/2" so you will need to cut some metal or use smaller speakers. I would be interested in what it took to remove the covering since I believe you have to remove the side plastic trim behind the back doors. One of my speakers is blown so it's time to replace all of them.
Old Jan 11, 2012 | 06:28 PM
JRL's Avatar
JRL
I put a pair of 8" Kicker free air subs in my 99T5 many years ago.
It requires some cutting, etc, but they will work and with even a small amp, (I had only a 100w amp) it sounded GREAT, (along with the rest of a new system, HU and door speakers.
I'm older and did not need to vibrate the ground underneath the car so 100 was fine.
A 200-300 amp would be a killer
Old Jan 12, 2012 | 02:12 PM
DaVolvoKid's Avatar
I have cut the bottom of the rear speaker baskets and the new 8s fit perfectly. I am not using free air subs but I am putting a box under the speakers mounted to the top of the trunk. I am using a 750W amp and a pair of 300W subs so it should provide the volume I want.
Just a note to anyone who is using the original baskets for 8 inch subs, make sure to put some foam tape on the bottom of the baskets to stop them from touching the metal. It will create a nice tight fit and eliminate any vibrations.
bkk7791
Jan 11, 2012 06:29 PM
KnoxVolvo
May 13, 2008 09:57 PM
redbandit850
Jul 17, 2007 12:15 PM
NCS60
May 21, 2007 07:00 AM
oldvolvo
Nov 24, 2005 11:19 PM
