Replaced transmission, still shifts hard. What next?
Old May 29, 2017 | 04:17 PM
Mcl9699's Avatar
Default Replaced transmission, still shifts hard. What next?
I just paid 900$ to have a used tranny put in my 2000 volvo s70.
It still shifts hard from 3rd to 4th gear. Any suggestions as to what to check next? The previous tranny still moved but not all the time and would stop working after a few minutes. Any suggestions, please? 200,000+ miles on the car, 140k on the new tranny.
Old May 29, 2017 | 06:04 PM
did you drain all the old fluid with the install? if not try a drain fill making sure you use the right ATF fluid and consider a synthetic. Double check the fluid level cold and warm. Only other things I can think of is maybe your transmission cooler is not working efficiently allowing the transmission to over heat or you just got a tired replacement transmission.
Old Jun 6, 2017 | 05:28 PM
bmdubya1198's Avatar
I would change the transmission fluid and see if that helps. Also check out your lower transmission mount/torque rod, it might be a little worn out and transferring vibration into the cabin.
Dom Rellik
1998-2000 model year V70
Feb 16, 2015 06:59 PM
shoeboxOH
2001-2013 model year V70
12
Feb 9, 2015 10:27 AM
vtxrider
Aug 9, 2013 08:55 AM
240wagongirl
Feb 7, 2009 02:23 PM
