Replacing Ignition Coils a big job?
Old Feb 23, 2009 | 09:32 AM
andwri's Avatar
Default Replacing Ignition Coils a big job?
Hi folks...
This is my first post, but what an incredible forum. I've spent about an hour on here this morning and have gained some incredible knowledge and resource. Thank you.
I have a '99 S70 (base model) and have been told that one of my ignition coils is bad and the other four have cracks in them and could go at anytime. My mechanic wants about $800 to replace them (along with new plugs). If I can do it myself, I can save a little over $500. Is it a big deal to change them out? I have some limited shadetree experience. I changed the plugs out myself a couple of years ago. Is replacing the coils a much bigger job than that? Any special tools required? Any tutorials anyone could point to?
Thanks in advance!
Andy
Old Feb 23, 2009 | 09:16 PM
It is super easy to replace them.
Remove the black spark plug cover(Volvo 24 valve cover)
Then you will see the coils which are being held in with a 10MM screw. Then they will slide out then unplug them and replace.
Old Feb 24, 2009 | 04:20 PM
jdp6000's Avatar
Careful not to over tighten the plugs. Ask for the torque spec for them. Your mechanic should know this or someone here will. Easy job.
Jim
Old Feb 25, 2009 | 07:44 AM
andwri's Avatar
Thanks so much to both of you for your input. It sounds like something I can certainly attempt.
roytoronto
Apr 26, 2009 10:59 AM
roytoronto
Apr 5, 2009 09:04 AM
sosajoe00
Apr 19, 2008 07:41 PM
Ham
Jan 16, 2007 10:00 PM
AT Girl
Aug 12, 2005 09:49 PM
