Replacing the light bulbs on the dash and gear shift
Old Sep 22, 2009 | 06:13 PM
lsmith49's Avatar
Default Replacing the light bulbs on the dash and gear shift
I have a 1998 S70 with the bulbs out up on the dash near the window, it's for the alarm. And the bulb that makes the gears light up on the shifter. Anyone know how to get into these areas? I don't see anything in the manual.
Thanks!
Old Mar 30, 2011 | 01:39 PM
ODONOVAN's Avatar
Default I have the same problem
I would not be so quick to think that it is the bulb that's broken , more than likely it is a fuse that's gone.The light on my gear shift does not light up but also the light for the radio buttons does not work. Coincidence?
Old Mar 30, 2011 | 11:39 PM
donf's Avatar
You both are most likely new to Volvos - these cars eat bulbs like candy. it ain't a fuse. Use search, lots of posts about radio lights (easy) and dash lights (harder).
Old Dec 2, 2011 | 06:19 PM
clinton's Avatar
any one knows how to change the bulb on the s70 volvo 1998
Old Dec 2, 2011 | 07:13 PM
Use a screw driver.
Old Dec 3, 2011 | 07:46 AM
ODONOVAN's Avatar
Default gear shift light
Originally Posted by rspi
Use a screw driver.
Very funny, but seriously does anyone actually know? I'm well used to searching but this one has stumped me good and proper.
Old Dec 3, 2011 | 09:13 AM
Well, there are about 50 bulbs on every car. Which bulb(s) as you asking about?
Old Dec 3, 2011 | 03:44 PM
ODONOVAN's Avatar
Like my message states ,the gear shift light.
Old Dec 3, 2011 | 08:09 PM
Odonovan, I don't even know what kind of car you have. Nor the year. This thread was started by someone else and you said you though you had a bad fuse. I'm going to assume you have a pre-'01 S/V70.
As for the gear shifter, you will have to take the center console out or loose to get the bulb out and another one in. You need to get a replacement from the stealer.
https://volvoforums.com/forum/volvo-...ement-s-16533/
http://www.matthewsvolvosite.com/for...hp?f=1&t=17553
The radio buttons have 1 bulb per 3 buttons. Here is the link for that (I have a few of these bulbs if you need some).
http://www.matthewsvolvosite.com/vol...placement.html
Old Dec 3, 2011 | 08:48 PM
ODONOVAN's Avatar
Alright thanks a lot
Old Nov 9, 2012 | 03:50 PM
s70fanman's Avatar
can anyone tell me how to check/repair the bulb for the alarm on the dashboard near the windshield?? The light on my radio but the alarm light on the dash will not come on and in my neighborhood an alarm light makes THE difference
Old Nov 13, 2012 | 04:07 PM
donf's Avatar
No idea but you might get more action if you didn't rehash an old thread which wasn't about other bulbs.
Old Nov 13, 2012 | 05:31 PM
Are you sure the alarm works? Roll a window down and lock the car. Then wait 10 minutes, reach your hand in the car, unlock the door, and see if the alarm goes off. If it doesn't, fix the alarm.
Old Nov 13, 2012 | 11:53 PM
TwinScrewZ32's Avatar
Default Youtube
IPD has a youtube video on how to convert your gauges to LED. Should be helpful in getting to the bulbs even if you just want to change them and not convert them.
FYI I looked into converting them and their kit is like $40 in case you're interested
Volvo_Neps
1998-2000 model year V70
Sep 12, 2024 06:53 AM
Arsenal6
Mar 21, 2009 08:45 PM
tr_car_nut
Jan 19, 2008 09:37 AM
panopticon
Mar 21, 2005 09:38 PM
