Replacing the light switch...how to ...?
Old Jul 5, 2011 | 08:30 PM
herbeapuce's Avatar
Default Replacing the light switch...how to ...?
Hi again.
can a good soul tell me the right way to replace the light switch on my Volvo S70 1998 ? I just notice tonight that the switch is playing tricks on my. it goes on and off on its own...
I hope I do not have to remove some of the dash please ...?
thanks you so much.
stef
Old Jul 5, 2011 | 10:00 PM
Pull on the dimmer just to the right of the switch. You can use a flat tip screw driver to get it started and wiggle it out. Once it's out put a finger or 2 through that hole and reach behind the light switch and push it out. Push hard, it will pop out and then pull on it and the wire plug will pop off.
Old Jul 6, 2011 | 10:53 AM
herbeapuce's Avatar
thank you once again.
I did that . worked like a charme.
I just found out it's part or a recall, so they will change it for free
best Regards
stef
bennyd20
Sep 23, 2011 07:34 PM
imnsight
Mar 7, 2011 05:05 PM
kollyn
May 17, 2010 11:44 AM
Old850
Aug 25, 2008 09:42 AM
