S70 Air Conditioner
Old Jul 9, 2013 | 06:32 AM
ernestawazie's Avatar
Default S70 Air Conditioner
Just recently the A/C fuse gets blown once i try to put on the AC. What could be the problem? What should the technician possibly look out for? Dont want them to do any trial and error thing with the electricals of the vehicle. Thanks
Old Jul 9, 2013 | 06:53 AM
Huh? If you take the car to a compident mechanic you have no need to ask this question here. They will not start messing with fuel pump wires trying to figure out what's wrong with the AC. And the last thing you want to do is try to go in there acting like you are going to tell them what to do and how to do it. You will get more out of mechanics and any other people if you stroke their ego or simply leave them alone to do their job.
Now if you are asking this question so you don't get taken advantage of, get a mechanic referral. Then let them know you were referred. Other than that, find a mechanic you can trust.
If the system is blowing a fuse you likely have a compressor that is locked up when engaged, a bad clutch, or some kind of switch that is bad.
Old Jul 9, 2013 | 07:00 AM
The main issue with AC problems is this, if any component that requires the system to be breached has to be replaced, a professional will require the dryer and some switch to be replaceded. The system has to be vacuumed down and reserviced properly. Most AC repairs range between $350 and $1,100. The low side is if the compressor is good.
Old Jul 15, 2013 | 08:18 AM
Dear rspi, i took the car to an electrician and they traced the cable that is connected to the compressor up to the brain box for possible bridging and they pulled on the cable from one end, tapped some loose cables on the main fuse box from under and the problem stopped. Right now the ac is back to life. Thanks for your interest in anything that concerns my S70.
Old Jul 15, 2013 | 08:37 AM
Mechanic or electrician? Sounds like you got it fixed for under $200, what was the cost?
Glad your AC is working.
Old Jul 15, 2013 | 09:19 AM
Dear rspi, it was an electrician that worked on it. All the work for about N1,200 Nigerian Naira. Though they are my regular electricians, they corrected the electric seat adjustment problem also. Thank you. How do i adjust the parking brake?
HarryO
Jul 15, 2023 03:58 PM
gianni
2001-2013 model year XC70
Sep 18, 2013 03:33 PM
austeve
Jul 29, 2008 09:08 PM
Carbuff
Jul 26, 2005 01:14 AM
Carbuff
Feb 22, 2005 12:36 AM
