S70 Dashboard Noise
Old Jul 15, 2013 | 09:36 AM
ernestawazie's Avatar
Default S70 Dashboard Noise
Please somebody should advice me on what to do to end this dash board noise as if the dash board is rubbing on something especially if i go on bumpy and unsmooth/rough roads. Its irritating.
Old Jul 15, 2013 | 10:13 AM
The dash has 4 or 5 mounting tabs that pull it tight to the firewall. The plastic gets old and breaks up. Some things help them break faster, like putting your foot on it, leaning on it, or someone pulling up on it. At any rate, when the tabs break apart the entire dash has to be pulled to fix/brace them. Lot of work.
You can Google search "Volvo S70 Dash Tab Repair" or go to www.MatthewsVolvoSite.com. Someone there has a current thread going about it.
Old Jul 16, 2013 | 08:25 AM
Dear RSPI, trying to locate the thread on the dash board repair without success. Will keep trying. I located the srew for the adjustment of the Hand brake and its ok now. The hand brake lever doesnt come up all the way, hittinh the arm rest. Just as i want it now. Will be happier once i can conquerthe dash board noise. The noise seems to come from the piece of plastic near the windscreen where the chassis number is tagged. It looks like its gonna be a big job. Gonna face it one day soon.
Old Jul 19, 2013 | 07:42 PM
Ryant5's Avatar
My dash was really squeaky, I just removed that plastic guard in front of the windshield to access the hardware that tightens up the dash, I think they were torx screws, mighta been bolts, but either way like a half turn on each one made a huge difference and it was only like a 20 minute job
Old Jul 19, 2013 | 09:19 PM
In this S70 section, the very first STICKY thread is the DIY thread that has a long list of DIY links. There is a link on that page that says "DASH TAB REPAIR" or something like that. Follow that link.
https://volvoforums.com/forum/volvo-...repairs-54525/
Old Jul 22, 2013 | 12:26 PM
Dear Ryant5, is it really that simple to remove the plastic guard in front of the windshield without breaking something undeerneat? Where do i start removing the plastic guard from? am so scared of breaking something. thanks any way.
Old Jul 22, 2013 | 12:42 PM
Very easy. There are about 7 screws across the cover, then pull the seal up and it pulls from under the trim under the windshield. 99 Times out of 100 the mounting tabs are broken. I guess it would be worth the try.
Old Jul 22, 2013 | 04:14 PM
Ryant5's Avatar
Hey sorry hadn't been on her in a bit! Just got your PM and pasted you the write up from MVS that I used, it tells you everything you need to know!
Old Jul 24, 2013 | 05:36 AM
Ryant5, seen your message. Will give it a shot this weekend. Thanks.
Old Jul 27, 2013 | 10:18 AM
Ryant5's Avatar
Let us know how it goes, should be a cake walk!
Old Jul 27, 2013 | 12:28 PM
Why not post the link and information here where other people can benefit from it?
Ahmed
Jul 21, 2014 11:57 PM
Ahmed
May 25, 2014 09:04 PM
wmlbiz
May 23, 2012 03:06 PM
duikboot
Nov 4, 2011 01:18 PM
trosaire
Aug 19, 2009 08:05 PM
