S70 four door malfunction
Old Mar 26, 2012 | 05:23 PM
PROMAKER's Avatar
Default S70 four door malfunction
Does anyone know how to get all four doors to open using the car keys? I have a 1998 S70.
Right now, my 4 doors won't open when I turn the key to the left twice. I don't have the remote.
Old Mar 26, 2012 | 05:47 PM
Lifesgoodhere's Avatar
it is in the drivers door lock module. only way to fix it is to replace it.
Old Mar 27, 2012 | 03:11 PM
PROMAKER's Avatar
Default Resetting the Alarm function
Thank you very much.
Is that the only way to reset the alarm function on a 1998 S70?
Old Mar 27, 2012 | 07:46 PM
instructions to turn the audible alarm back on is in the owners manual for your car.
Old Mar 28, 2012 | 02:04 PM
PROMAKER's Avatar
Default Thanks
I appreciate it. I'll check it out and let you know.
Old Mar 28, 2012 | 07:39 PM
PROMAKER's Avatar
Does anyone know where to buy a "lock door module" for a 1998 S70 online?
Old Mar 28, 2012 | 07:53 PM
PROMAKER's Avatar
Default door latch actuator
Thanks.
Is the drivers door lock module the same as the door latch actuator ?
e.
Old Mar 30, 2012 | 06:17 AM
I don't think so and that is usually the problem with the S/V70's. Each door has it's own door latch actuator that the little motor inside gets to weak to unlock/lock the latch with the others. The only way to fix the problem is to replace the latch assembly. Those things are expensive . I have not figured out a way to tell if the ones in junked cars are new or not.
Old Mar 30, 2012 | 06:50 AM
yes module, actuator, same thing.
NOT THE SWITCH WITH ALL THE BUTTONS.
Old Mar 31, 2012 | 03:38 PM
PROMAKER's Avatar
Thanks much.
Old Mar 31, 2012 | 03:39 PM
PROMAKER's Avatar
Thanks.
Kimmen
Jul 26, 2011 12:35 AM
FredRydr
Jun 12, 2011 09:42 AM
seamonkey
Sep 27, 2009 09:58 PM
malaka
Volvo C30
Aug 10, 2009 03:05 PM
iamnickcarter
Oct 29, 2007 01:03 AM
