s70 rear fog light.. only one?
Old Sep 13, 2008 | 06:12 PM
cm123's Avatar
Default s70 rear fog light.. only one?
i was backing up my car into my garage today , and my friend told me that i only have one rear fog light..
i went to check and it was true. the hole where the bulb is suppose to go is covered.. can anyone tell me why there is only a rear fog light. and are you able to fix that?
thanks,
cm123
Old Sep 13, 2008 | 06:17 PM
reg's Avatar
reg
Default RE: s70 rear fog light.. only one?
European autos use but one rear fog lamp. It is always located on the left side of the auto.
r.
Old Sep 13, 2008 | 06:20 PM
cm123's Avatar
is there a way to make the other one function?
Old Sep 13, 2008 | 08:52 PM
Is is supposed to be illegal to use both here in the U.S.
But yes you can knock out the plug in the taillight and install a bulb and you are done.
Old Sep 14, 2008 | 04:04 PM
S70GLT's Avatar
ORIGINAL: tech
hmmm.. never knew that, I knocked out mine and installed a bulb, in fact, before I did this I was told once by a VT state trooper that I had a bulb out in the rear when in fact I just had my rear fog on.
Old Sep 15, 2008 | 04:31 PM
Yes I am running mine a dual as well and never had any problems will continue to run till I have a problem.
rspi
Apr 4, 2009 09:15 AM
zoetical
Jan 24, 2009 02:46 PM
eurotrash
Dec 11, 2008 01:25 PM
