Power seat problem - only one side moves...
Old Apr 3, 2009 | 08:21 AM
Default Power seat problem - only one side moves...
I have another small problem with my '97 960. The passenger side power seat does not move forward and back properly. When the switch is pressed only one side of the seat moves, forward or back. As expected, that one side will only move so far as it twists the seat out of shape.
Temp fix: For now, I have tapped the cable to the motor back, in a certain possition so it will work. Does anyone know of a place to get a cable to fix this or some other permanant repair?
Old Apr 4, 2009 | 09:15 AM
The cable has stretched(Common) You can replace the cable or heat the end with a mini torch and slide the metal end in more and fix it.
manoduv
Aug 26, 2013 01:15 PM
moosey
Mar 14, 2013 02:55 PM
orangefob7
Aug 18, 2009 09:14 AM
snkpkp
May 13, 2009 08:52 PM
