S70 Steering
Old Dec 31, 2009 | 10:53 AM
Vee70's Avatar
Default S70 Steering
Hi - I have a 1999 S70 which recently had a steering rack replacement. When it first came back from this repair the steering was very tight. But then a leak was discovered due to the wrong type of hydraulic hoses being used. After this was remedied the steering appears to be much looser. Is it possible that the rack was somehow damaged to do the loss of fluid during that time>?
Thank you!
Old Jan 4, 2010 | 09:31 PM
When you say looser, does that mean the car drifts? If not, maybe it's fine.
Old Jan 4, 2010 | 11:07 PM
Carrots's Avatar
The hydraulic leak probably reduced the amount of power assist, making the steering tighter than it should have been. I know of no way that the power steering would become stronger than stock... Your steering was probably too tight before the pressure leak was fixed. Unless, like rspi said, your car is wandering... then there's a problem.
Old Apr 3, 2010 | 09:33 PM
hordezla's Avatar
How do you know which steering rack to order? There are 2 of them available out there, Sweden made (FC1) and Belgium made (FC2)?!
Old Apr 4, 2010 | 01:29 PM
hordezla's Avatar
I took my steering rack put today (what a pita job) and tomorrow i will buy new one. These are the numbers I copied from the sticker found on the rack itself: p9140421 , tef02a019. Is this Belgium od Sweden made, does anyone know?
thanks!
al_ngl
Nov 23, 2011 12:06 AM
2002v70
Oct 17, 2009 06:31 PM
nehopsa
Jun 24, 2008 11:20 AM
intence
Mar 3, 2008 08:40 PM
katiejoyful
Dec 12, 2007 04:49 PM
