Serpentine Belt replacement
Old Mar 16, 2009 | 05:55 PM
jg1's Avatar
jg1
Default Serpentine Belt replacement
Have an S70 that is due for replacement of the serpentine belt -- first time I bought it from Volvo no problems. I am wondering if I should use an aftermarket belt here is what I found that is available:
Hutchinson for $16.90
Gates for $38.21
Conitech for $27.02
Any suggestions on which is better or should I just stick with original Volvo part which I haven't priced yet. Also if I go with an aftermarket as above would the replacement interval still be 60k miles?
Thanks in advance. A lot of great info on this site
Old Mar 16, 2009 | 08:06 PM
Johnny Mullet's Avatar
Yes, the interval is still the same. Price the Volvo belt and if it's less or equal to the Gates, then get it. I like Gates belts and use them on all my rides, but a factory part will last also. Never use cheap belts from discount auto stores.
Old Apr 17, 2009 | 07:46 PM
lmchle's Avatar
Default 1998 S70 Serpentine Belt ( Help Me Please)
Im trying to replace the serpentine belt on my s70. Im not using the serpentine tool. Can someone please tell me what size socket wrench do i need to use to fit inside of the hole on the pulley? I cant use a 1/2 its too small. Do I use a 36mm?
Old Apr 17, 2009 | 08:56 PM
BlazeS70's Avatar
Probably. Just run through all of your metric sockets until you find the right one. I wish Volvo wouldn't have such a great variety of screw sizes...
Old Apr 19, 2009 | 07:52 AM
FredMc's Avatar
can't believe the crappy answers you got to this. All you wanted to know was how to move the tensioner to remove the serp belt. You got answers like crow bars and so on.
Here: get it from this forum...
http://volvospeed.com/Repair/sbelt70.php
Old May 18, 2009 | 12:10 AM
redikqliss's Avatar
hey does anybody have the serpentine belt routing for a 98 S70?
Old May 18, 2009 | 01:07 PM
lmchle's Avatar
Default Picture of routing for the serpentine belt
pg. 128 Drive belt, Air pump system
[IMG]file:///C:/Documents%20and%20Settings/HomeUser/My%20Documents/1998%20S70%20&%20V70_files/fff215.jpg[/IMG]
Old May 22, 2009 | 08:10 PM
owenmpk's Avatar
Imchle, you linked the image to your local system you need post on the internet or insert the image
Old May 24, 2009 | 05:13 PM
lmchle's Avatar
Use the S-70 Manual pages 126-129 and it will show u a picture of how it should be threaded.
Old Jun 5, 2009 | 02:33 AM
redikqliss's Avatar
i'd love to see that image. I have a manual for it but the reason i ask, because the belt routing i have currently does not match what the manual says. Also the manual goes by an older model of an 850....few things are the same but others i cant rely on it basically....Can somebody place a pic up of their belt?
Old Jun 5, 2009 | 11:23 PM
gdog's Avatar
Attached is what i got from IPD when i got my belt for my 850; looks like it's the same for S70 thru '98. Sorry for the low resolution but that was necessary to get it under this site's files size limitation.
Apparently they changed the routing afterward; that's why the manuals are wrong.
File Type: pdf
Old Jun 12, 2009 | 02:26 AM
redikqliss's Avatar
AWSOME!!! thanks so much!!!
Old Jun 12, 2009 | 11:53 PM
gdog's Avatar
De Nada
Old Mar 8, 2010 | 08:09 PM
Rb_newsletter@yahoo.com's Avatar
Question
I saw jg1 mentioned the prices below for serpentine belts.
Gates for $38.21
Conitech for $27.02
I wonder where can I get the gates belt? Is there any reliable website?
Tim Sway
2001-2013 model year V70
Apr 12, 2013 10:43 PM
iscwebe
Feb 9, 2010 12:50 AM
StnThree
Aug 18, 2009 10:28 PM
lmchle
Apr 18, 2009 10:29 AM
tr_car_nut
Jan 24, 2008 05:50 PM
