MY LIGHT has been popping up recently on start up,my spark Plugs and wires are new,so is the distributor cap and rotor and gas filter,new oil change and filter as well
what else should I change or check
If it is only the service light then it is a reminder light.
You need a special tool to reset it.
It is programmed to come on every 7,500 miles.
If you had the oil change done at a Dealer they should have reset it.
Did you always change your own oil?
If not then how often did you change the oil before.
Like I stated above it is programmed to come on every 7,500 miles.
