What's wrong with my 1998 S70
Old Sep 7, 2008 | 05:01 PM
nosweat's Avatar
Default What's wrong with my 1998 S70
I have a 1998 s70 GLT. And I found that it consume a lot of gas 12-13 mile per gallon in local. I do not know what' s wrong with my car. which part should be inspected or changed? Whether changing timing belt can help the car? Thanks.
Old Sep 7, 2008 | 05:02 PM
nosweat's Avatar
Default RE: What's wrong with my 1998 S70
also my car has a high mileage about 140k mile
Old Sep 7, 2008 | 05:03 PM
Last tune up?
Check engine light on?
Does it run ok?
Old Sep 7, 2008 | 08:01 PM
RedS70guy's Avatar
Check to see if you have a vacuum leak at the elbow near the power steering pump. The gas mileage on my 98 S70 w/90k miles was in that range until I had that fixed. Search a bit here and on the web and you will find some additional info. Cheap and simple to fix, cost me about $50 at a nearby garage. Mine did throw a code (p0172) and the Check Engine light was on. Cleared the problem and mileage was back up to normal.
Good luck.
Old Sep 8, 2008 | 12:15 PM
nosweat's Avatar
Thanks. The chech engine light is not on. All the light is off. And the car runs well.
How to check the vacuum leak? I am living in Chicago. Could you give me some suggestion on where to fix this problem without costing a lot of money? Thanks
Old Sep 8, 2008 | 12:40 PM
RedS70guy's Avatar
Read the information here: http://volvospeed.com/Repair/vacuum_lines.php
The first picture on that site has the rubber elbow that caused me the problem. Basically, the computer starts sending too much fuel to the engine thinking it is lean- that is one reason your mileage may be low. It is a little difficult to find, its near the power steering pump on the passenger side. When I finally looked at mine, there was a hole right through it. Had it replaced and been ok since.
Old Sep 8, 2008 | 10:53 PM
nosweat's Avatar
Thanks. I will try this weekend.
Whether the engine light should be on when there is the vacuum leak problem? Thanks.
corrybland@yahoo.com
Mar 29, 2014 08:53 AM
Motorman15
Jan 11, 2014 01:19 PM
predxen
Mar 24, 2013 01:43 PM
turpentine
Jul 28, 2007 04:50 AM
J Telectro
Jan 10, 2007 09:25 AM
