SERVICE-VEHICLE Light Came On
Old Aug 11, 2009 | 07:00 PM
Ruskya Mafia's Avatar
Cool SERVICE-VEHICLE Light Came On
i drive 98 s70 glt and my service light came on the other day. i was just wondering if i got something to worry about and wat are somethings that i have to check so they are in good condition or not. and by the way i got 143 miles on it
Old Aug 11, 2009 | 08:40 PM
Somthngfrce's Avatar
Service light comes on every 5k in miles. I call it the "Oil change light".... That's different fromt the CEL... I would say have it reset if you use a Stealership for oil changes or if you use a independent Volvo shop... Other wise it shuts off after 30 seconds, I believe..
Old Aug 12, 2009 | 12:34 PM
yea it shuts off after like 2 min or so. but i change oil myself. im just gonna go to a dealer and shut it off there
Old Aug 12, 2009 | 01:03 PM
98_S70_T5_Driver's Avatar
I think you can turn off the service light yourself by moving the key between positions. Search the forums and I'm sure somethings out there.
Old Aug 12, 2009 | 01:26 PM
Sorry, I forgot you had an S70. You don't need the stealer fo anything . You can do it your self..
Old Aug 12, 2009 | 01:32 PM
here you go. here's the sequence for that. The procedure is:
1. Press and hold Trip Odometer reset button
2. Turn ignition key to run position KPII(not the start position)
3. Wait 30 seconds or until service light begins blinking
4. Release Trip Odometer button
5. Turn ignition to off position
Old Aug 12, 2009 | 07:45 PM
Carrots's Avatar
That doesn't work on the '98 S70... '98's the "bastard" year that you can't reset yourself, and can't program a key fob yourself, either.
Old Aug 12, 2009 | 07:47 PM
Carrots's Avatar
I actually meant... you have to have a special tool to turn it off. They cost about $150 or so, and most will also read ABS codes, too
Old Aug 13, 2009 | 02:12 PM
yes exactly. i did one of those "do it ur self things" but it didnt work, so i went to my mechanic and he told me that i cant do this to 98 models. but i called to a local volvo dealer and they told that they can turn it off for free
Old Aug 14, 2009 | 09:47 PM
ok they turned the light off, everything back to normal
HelgaTheS80
Jan 4, 2017 12:16 PM
colgate41
Feb 12, 2007 09:16 PM
mwr
Aug 8, 2006 01:41 AM
boondoc
May 7, 2006 10:25 AM
S70driver
Jan 26, 2006 10:07 PM
