Slight shuddering in reverse???
Old Mar 25, 2009 | 04:00 PM
hrtrhb's Avatar
Default Slight shuddering in reverse???
Recently purchased a S70 from a family who had it 4-5 years. Has 181k, but in good physical condition. Drives well However, today I found when I put in in reverse, the moment I gave it some gas there was a slight shudder when moving backwards. I really don't know, but maybe the transmission slipping?? However, the car will "creep" backwards without any problem with very slight vibration. The car seems to drive fine otherwise. Anybody experience this? or have any ideas??? Thank you
Old Mar 25, 2009 | 06:55 PM
Check the fluid level first.
Then check engine mounts next.
Old Mar 25, 2009 | 09:03 PM
s70_t5_1999's Avatar
the transmission will not fully shift into reverse for 1-2 seconds.
if you give it gas before that, it will pull back pretty rough. i have experienced this myself but i know in the owners manual it says there is a short delay when shifting into reverse.
Old Mar 26, 2009 | 06:35 AM
hrtrhb's Avatar
The hitch is...the car drives well forward... and the car shudders as long as you have your foot on the gas pedal going in reverse. But...the car creeps backwards so wouldn't that mean reverse has been engaged??? Thanks for your replies too!
Old Mar 26, 2009 | 05:16 PM
i guess your problem might be different. i noticed that if you press the gas before the 2 seconds while its engaging it will rev up, then CLUNK... you're in reverse going 9-10
Old Mar 26, 2009 | 07:52 PM
Fluid full and clean?
BigGreen
Sep 16, 2009 05:11 AM
uncle
Dec 3, 2007 06:48 PM
Beardog
May 26, 2007 02:48 PM
syncan
Jul 9, 2006 12:50 AM
cgerdeman
Feb 27, 2006 04:00 PM
