temp. needle
Old Mar 4, 2008 | 07:24 PM
Fixityourselfer's Avatar
Default temp. needle
The temp needle on my dash(98s70T) goes to the 3:00 position when the car has warmed up.......in warm or nice weather. if it gets cold, it will only go to the 3:30 position, and when its very cold(around 35-40F or less) it will only go to the 4:00 position-even though i'm driving down the highway and the car has been on for an hour. fuel mileageseems poor when this is going on.
ect and thermostat are new oem.
I believe this is affecting my fuel mileage. isn'tthe needlesupposed to go to 3:00 once warm no matter the outside temp?
Old Mar 4, 2008 | 07:50 PM
Default RE: temp. needle
Yes it is.
Are you sure they gave you the correct temp thermostat?
Old Mar 5, 2008 | 06:49 AM
65mustang's Avatar
I agree with tech. My S40 did the same thing. When I went for a thermostat, they had one at 89 degrees and one at 92 degrees wherever I looked. I went with the higher and it went away.
Old Mar 5, 2008 | 08:31 AM
JimKW's Avatar
My tem gauge on all three of mine stay right at 3:00 once it's warmed up. When I replace thermostats I go with the 92 or I might have even gotten a95 if Volvo makes one. I know I bought the OEM one called for in my car.
Old Mar 13, 2008 | 12:13 AM
i've changed the thermostat twice now in trying to fix this problem, and the issue continues. the first was a oem(vernat) 87degree, the second one(in car now)a duralast 92degree. is there anything else that can be responsible? my coolant temp sensor is only about 5-6 mos old, (my mechanic said to change it when i got inspection) and the car was running fine till about 10 weeks ago. fuel mileage is not as good as usual. if the car is running and stopped, the needle will rise up. drive off, and it drops.
Old Mar 13, 2008 | 07:22 PM
HMMM not sure sounds like a flow problem.
Any check engine light?
nimzo
Aug 28, 2010 08:54 PM
dgjohns
Dec 8, 2009 07:01 AM
Mr Sheen
May 12, 2008 08:14 AM
DJboozeAlot
Nov 27, 2006 08:54 PM
van850
Jun 21, 2006 03:24 AM
