timing marks
Old Jan 12, 2009 | 12:34 PM
mtvolvo98s70's Avatar
Default timing marks
I had the tensinor go out on my 98 s70 just as i was starting it not sure if it did any valve damage yet. When i took the cover off the belt had road out on the cam pullies and eat the time marks off the cover. I had found out that the settings should be at 11 and 1 . when i set it by guessing it turn free but when i tried to start it turned like it had no compesion. If it is off by a one of the teeth would that keep it from not starting
Old Jan 12, 2009 | 04:47 PM
Default RE: timing marks
If the timing jumped when you went to start it most likely you have bent valves.
whtgtz
Sep 9, 2012 03:51 PM
Carbuff
Dec 28, 2009 06:24 PM
Soloracer
Aug 26, 2006 04:43 PM
ebrobb
Aug 10, 2006 08:25 PM
