Transmission Fluid
Old Nov 10, 2022 | 04:47 PM
spike17128's Avatar
Default Transmission Fluid
Good evening,
I'm going to change out the transmissions fluid but I cant figure which type I need. The manual says Dexron III and Mercon?
Are they interchangeable? Can someone point me in the right direction?
I have a 2000 S70GLT front wheel drive
Thanks
Old Nov 10, 2022 | 08:39 PM
Yes..
Old Nov 11, 2022 | 11:02 AM
spike17128's Avatar
Thanks!
Old Nov 11, 2022 | 12:34 PM
many brands label their ATF "Dex III/Mercon"and you can find both regular and synthetic formulas. Dex vs Mercon is as simple as Dex is a GM standard and Mercon is Ford's standard for ATF! Note that the are also other Dex formulas ie Dex VI etc which are not compatible to your model so sticking with the manual's recommendation is the way to go.
Old Nov 11, 2022 | 06:18 PM
spike17128's Avatar
Understood. Thanks!
Psaboic
Jan 22, 2022 09:36 AM
kirk54
1998-2000 model year V70
Feb 14, 2013 07:09 PM
DontaviousJones
Apr 5, 2011 10:26 AM
mason_200
May 17, 2010 09:48 AM
shuv70
Dec 29, 2005 06:02 PM
