transmission fluid!
Old May 20, 2009 | 07:57 PM
turbo4door's Avatar
Default transmission fluid!
What is the proper way to replace the tranny fluid in my 2000 s70? And what size bolt is the tranny fluid pan bolt?(The bolt that drains the tranny fluid) thanks guys!
Old May 20, 2009 | 08:55 PM
You can do a bunch of drain and refills or remove the cooler line and pump it through the system till you have 12 quarts through it. The drain plug is 15/16 or comparable in metric.
Old May 24, 2009 | 09:17 AM
turbo4door's Avatar
Ok. Before I get started. What is the correct way to check the transmission fluid level? When parked, engine at operating temp, and in neutral, where should the the fluid level b?
Old May 24, 2009 | 09:30 AM
The car should be warm and in park and should read in the middle of the hot part on the dipstick.
Full on the hot side should be after the car was driven for a little while.
Old May 24, 2009 | 09:40 AM
turbo4door's Avatar
I drove it about 20 miles and checkd it. Engine on, in park, the fluid level was 3/4 on the cold mark! So when I add fluid, do I leave the car running and just fill it to the 1/2 mark of the hot level?
Old May 24, 2009 | 10:22 AM
Doing it that way is fine.
Old May 24, 2009 | 10:27 AM
turbo4door's Avatar
I appreciate that! Thanks TECH!
AustinPower
Nov 11, 2008 07:43 AM
flyingo
Apr 27, 2005 07:19 PM
94volvo850
Feb 18, 2005 06:49 PM
